strange noise on 04 disco
Old Apr 9, 2009 | 12:18 PM
socalrover's Avatar
Default strange noise on 04 disco
have an 04 disco with 57300 miles and recently noticed a weird high pitch noise coming from the front end of the truck. the noise tends to get worse when i turn the steering wheel and is worse when the truck is cold just after startup. sounds like a straining loud high pitch sound everytime i hit the gas and turn the steering wheel. just noticed the noise about 2 days ago. any ideas? thanks in advance.
Old Apr 9, 2009 | 05:34 PM
sloppyjoe's Avatar
power steering pump,,,
try changing the fluid and see if that helps,,,
im betting you dont know if it has ever been done
Old Apr 9, 2009 | 05:41 PM
Go look at your belt, good possibility would be a bad betl and with your mileage a new belt tensioner and 2 idler pulleys, all of which do fail and cause a whine.
With your mileage, it is time for a 60K at which time you should flush the p/s fluid along with everything else.
Old Apr 9, 2009 | 06:00 PM
sloppyjoe's Avatar
dang,,,,mike
i forgot the belt and pulleys. are the pulleys shot by the 60k mark?
Old Apr 9, 2009 | 06:50 PM
Can be, I got mine replaced under my factory warranty while doing the 45K.
adowgiert
Jul 1, 2023 12:06 AM
Twjones
Mar 29, 2015 07:35 PM
nashville rookie
Aug 27, 2008 04:48 PM
Durfee
May 25, 2006 02:21 PM
