Strange noise
Strange noise
I have a 2002 landrover discovery TD5 and recently I have noticed that after a longish run (usually on the motorway) as I slow down a loud whining noise can be heard. It is worst when turning bends/corners. Even when the car is stationary when you turn the steering wheel it makes the noise. Does anyone have the same problem or know how to solve it. It gets worse as the engine warms up as it doesn't happen(or its a lot quieter)when I first start the car in the mornings or whenI leave work.
Thanks
L
x
Thanks
L
x
RE: Strange noise
Check your power steering fluid level. Sounds like it is low, once the fluid gets hot it cannot do it's job as well and the noise that you are hearing is the power steering pump.
It might be a good idea to have the poweer steering fluid changed, top it off before you drive it though. You dont want to burn up the pump.
