strange noise while reversing WTF?
Old Aug 21, 2012 | 02:21 PM
lr2001silver's Avatar
Banned
Question strange noise while reversing WTF?
2001 DII
100,000 miles
Up to date all fluids new prop shaft
Okay so i was parked on slightest incline in my driveway same place i always park. I put truck in reverse to back out and heard a clicking sound as i started to move about three feet in reverse pressed on brake checked to make sure i was in gear all the way and i was so i put in drive pulled forward a few feet and tried again this time no noise? This is the first time i ever heard a noise and i bought this new.
Any thoughts as to the noise?
It was more if a plastic clicking sound vs metal sound
Old Aug 21, 2012 | 05:23 PM
So, have you replaced your front shaft, have you checked/drained your diff's and t/case looking for metal chunks and when was the last time you serviced.checked your tranny fluid?
Old Aug 21, 2012 | 07:56 PM
Banned
Yes, covered in first line stating up to date on all fluids and new prop shaft
no metal chunks ever. fluid changed on or before lr maintenance schedule calls for always from day one.
I use lrn 13754 in trans and lro 19727 in diffs the only part of my truck that is not factory is the front shaft anything that has been changed for preventive maintenance has been replaced with land rover only parts.
Old Aug 21, 2012 | 08:46 PM
Its only happened once so far?
Dont worry about it, it needs to happen more than once before we can investigate, could have been a stick stuck in the wheel well.
A cat toy in the engine fan, could have been anything.
Are your neighbors missing any of their kids?
Old Aug 21, 2012 | 09:05 PM
Banned
Lmao yes only once spike, it kind of sounded like it was in-between gears but the selector was in reverse position.
Old Aug 21, 2012 | 09:52 PM
But was the t-case all the way in gear?
Short story, driving to work while climbing a hill on the highway I hear a faint metallic rattle/ringing, its winter time, so its dark.
Noise goes away once I level out.
Next day, no noise, weeks go by, noise happens again.
Turns out it was my work van keys laying against the t-case shifter and the strain of climbing the hill was making the t-case shifter vibrate and the keys were vibrating thus the noise.
Moved keys, no noise.
Old Aug 21, 2012 | 10:04 PM
Banned
Nice story, glad it was something so simple! Now lets just hope i never hear that noise again.
Old Aug 22, 2012 | 08:17 AM
Don't figure since it has only happened once it won't do it again, cause it could and if it does you need to take it more seriously. My money would be on the t/case cause the tranny, for the most part won't make the noise you described.
Old Aug 22, 2012 | 12:25 PM
Banned
Thanks Mike i will be changing the t-case fluid again today to look for any signs of shavings or grit. I hope it was just somehow not in gear all the way, i know better than that and fear the worst when i hear any clicking sounds.
adowgiert
Jul 1, 2023 12:06 AM
Diverjohn
Feb 9, 2011 01:42 PM
Diverjohn
Nov 11, 2010 03:53 PM
shadrak1960
Apr 2, 2009 10:45 AM
scottiedoo1975
Freelander
Nov 8, 2008 08:13 AM
