Strange single tick when slowing or speeding
Old Jun 2, 2009 | 01:49 PM
99landroverdisco's Avatar
Originally Posted by okdiscoguy
That sir, is not a tick it is a clunk.
It is caused by slack in the driveline. some play is ok. I have about 1/4" radial travel on my flange. replace all of your gearing and it will go away, or you can just not slam it into drive and go for another 100K. relatively normal
Ok, thanks for the advice. So this is relatively normal on older discos. that's good to hear. Thanks.
Cheers.
Old Jun 2, 2009 | 01:56 PM
Originally Posted by forzabarca
I crawled up underneath and took a look at the front drive shaft. I didnt see the 3 grease fittings and a plug. But then again, I may not be completely clear what I am looking for.
I have been reading up on the u joint rebuild but do you all think that this is what is causing the strange tick sound it is making?
Then find a shop that can check your truck before you break something. If they find something and give you an estimate, get back to us with that so we can make sure they are not taking advantage of you.
Old Jun 2, 2009 | 04:38 PM
You are looking for three of these "nipples" all in one spot.
[IMG][/IMG]
If you change your gear lube and switch to 85w-140 it will cure/reduce your driveline "clunk"
xengineguy
Nov 12, 2015 12:23 PM
XCELLER8
Sep 19, 2009 03:27 PM
zracin
Mar 7, 2008 01:17 PM
Kraftyz51
Aug 19, 2007 03:58 PM
97XD
Feb 2, 2007 07:46 PM
