Strange Stalling
Old Mar 27, 2013 | 08:07 AM
bostow1's Avatar
4wd High
Default Strange Stalling
I have a 2001 Disco with 75k miles. Occasionally it stalls for some unknown reason. I cleaned throttle body, Cleaned MAF, I changed Crank Shaft Position Sensor. I don't know what else to do. It's so unpredictable when it happens but usually after accelerating and coming to a stop is when it cuts off. Any tips?
Old Mar 27, 2013 | 08:32 AM
When was it last tuned and do you have any fault codes, if so what are the fault code numbers?
Old Mar 27, 2013 | 10:17 AM
bostow1's Avatar
4wd High
No fault codes. I've never had a tune up but have only put 5k miles on it since I bnought from Land Rover dealer. You think a tune up could fix?
Old Mar 27, 2013 | 11:43 AM
drowssap's Avatar
what color are your ignition wires?
Old Mar 27, 2013 | 06:21 PM
bostow1's Avatar
4wd High
I'm sorry. But what do you mean by ignition wires?
Old Mar 27, 2013 | 06:29 PM
Snafu / Disco Fries's Avatar
If no codes and after giving her gas then coming to a stop you might want to look at the easy things first:
A bottle or two of good fuel injector/fuel system cleaner
Check to make sure air filter isn't filthy or air intake clogged up
Old Mar 27, 2013 | 06:34 PM
Also...be sure to check all your vacuum lines and the idle air controller too.
Old Mar 28, 2013 | 10:30 AM
SuperSport's Avatar
Maybe take it back to Land Rover and see if they might offer to look at it for free since it's fairly new to you from them?
According to his above question (what do you mean by ignition wires?), it might be good to take it to an independent mechanic if Land Rover does not offer to help for free.
sparky2008
Jun 5, 2008 11:01 AM
MikeRover
Jun 25, 2005 04:34 PM
slamwhit
Jun 17, 2005 05:11 PM
trailhead4x4
May 25, 2005 08:48 PM
Bene
May 1, 2005 04:21 AM
