Strange story (kinda long, hopefully entertaining )
Old Jul 23, 2012 | 12:32 AM
oilspotLR's Avatar
Not sure why they would fit the locks but the DI key and DII key are the same length/pattern. I didn't want to buy the key with the remote at the dealer so I bought a DI key. Had it cut and away I go with the new key working flawlessly!
Old Jul 24, 2012 | 12:38 PM
Andy2Rover's Avatar
So Spike....
I can go to my local hardware store, and if the have the ilco rv4 key blank, they can cut me a new D2 key from my OEM D2 key? Is the ilco Rv4 a fairly common blank that I can expect my local hardware store to have?
Sorry if I am hijacking!
Thanks Spike!
Andy
Old Jul 24, 2012 | 02:34 PM
jfall's Avatar
I had a key copied at the HW store.
The copied key did not work unless it was held straight into the door lock
and wiggled whilst trying to turn.
Same with the ignition.
The lock cylinders wear - as do the keys.
Making a replica of a worn key does not seem to do well.
Even if they cut a new one from the VIN, the lock cylinders are worn.
Old Jul 25, 2012 | 01:33 PM
RoverMasterTech's Avatar
When I worked at the dealer, I walked out with a customers key, pushed the button, lights flashed and door unlocked, started it, drove it on my lift, picked it up in the air, started to take the filter off and it looked new. The plate number and the color were different, on the work order. lo and behold 2 2004 discos with the same key, that could unlock and lock each other with the remote, 6 parking spots away from eachother...
Old Jul 25, 2012 | 02:06 PM
jafir's Avatar
that's spectacular.
I thought about programming both of my key fobs to both cars (Since currently I only have one each), but I figured it might cause problems when they are both within range.
Old Jul 25, 2012 | 09:01 PM
A copied worn key has a better chance of working than a brand new one cut from the VIN#.
We just went though this with my wifes van, I had a key cut with the VIN, would not work at all.
Took the whole van to the dealer, 4 keys and 15 min with a file later the key works.
Had a copy made of the worn out key and it works great first time.
azdevils013
Jan 21, 2012 10:52 PM
paolob
Nov 18, 2011 09:59 PM
twoxred
Jan 17, 2011 02:18 PM
SpecialK
Feb 14, 2009 11:08 AM
