Stripped Head Bolt - Any Help?!
Old May 5, 2010 | 08:08 AM
audiS4S6's Avatar
Originally Posted by Willie00d2
What size socket did you use? A 5/8"(.625) fits better then a 16mm(.630) I had to use a breaker bar with a jack handle over it to loosen mine, they are really tight. A short wobble extention helps with the rear bolts. I have never tried a extractor like that, looks like it would work.
Willie
I was using the 16mm when I bitched it up. Then I found that the 5/8" fit and tried that. Too late.
I was flexing my 1/2" drive Crapsman breaker bar with a pipe to get the other bolts loose.
Old May 5, 2010 | 08:10 AM
audiS4S6's Avatar
Originally Posted by greenwade
Just make sure that the tool manufacturer has a lifetime, no questions asked warranty. That way when you break it they will just give you a new one. I LOVE my Snap-Ons but i also love my craftsman tools at 1/5 of the cost.
Each brand has its place. I hate Craftsman sockets as they are just not strong enough or low profile enough. Snap On is hard to justify unless you are a professional mechanic. I was, and believe me, sometimes you need a Snap-on (or Mac) tool...
Old May 5, 2010 | 10:54 AM
greg409's Avatar
It's funny, I'd say most of us have the same tools, I'm 1/2 craftsman, 1/2 snap-on, a few proto pro and a couple of specialty (bent wrenches, ground down sockets)
LOL
luck,greg
Old May 5, 2010 | 12:13 PM
IBA 270's Avatar
All craftsman here. Many of those passed to me from my dad. I've always had great luck with them...never a problem.
On the headbolt...damage is done I'm affraid. Try everything short of heating it with a torch. If push comes to shove, you can always carefully grind the head down to get it off, then you've got more options.
Old May 5, 2010 | 12:20 PM
lipadj46's Avatar
I used these (actually the metric ones) on a rounded rear head bolt:
http://www.harborfreight.com/hand-to...ets-96334.html
Worked so great the extractor is still attached to the head bolt. It saved my ***, great tool for the money.
Old May 5, 2010 | 12:44 PM
Danny Lee 97 Disco's Avatar
I bought the sets from Sears. Look nice, don't work worth a damn. And that was on a caliper bolt.
Here's a couple of links on extraction practices.
http://www.asashop.org/autoinc/may2003/techtotech.htm
http://www.youtube.com/watch?v=cTRUXRv2HFs
Have fun. pray to the ROVER GODS BEFORE YOU START. Chant three times, Don't let me break anything that ain't broke yet. If I do have to break something, don't let be the most expensive part. Offer a ceremonial sacrifice of some sort, and plenty of Cold Beer to put out any fires you accidentally start.
Old May 5, 2010 | 01:34 PM
Burncycle's Avatar
3rd Gear
Bolt extractor isn't gonna do much good if it is on there tight enough. I tried the craftsman and snap on sets when I rounded off one of my head bolts. Get yourself a 5/8 HUSKY impact socket from home depot. They seemed to hold on much tighter than my regular craftsman 5/8 socket (which I sheared 3 of in two on one bolt). Make sure it is on there good, get plenty of leverage, and go slow.
Old May 5, 2010 | 02:09 PM
greg409's Avatar
I, like you, may be a little apprehensive about torch & head.
In the past, when I've had a scary bolt in alum, I've scared the head of it back using a large drift and a slap with my lil' buddy (2lbs).
You may try that to get it's att'n as you put on the extractor socket.
luck,greg
Old May 5, 2010 | 02:38 PM
lipadj46's Avatar
Hey don't listen to the guy who rounded of a rear head bolt and used a bolt extractor (mentioned above) that DID fit in the bolt space and did remove the bolt. A torch is your last resort and you really need to know what you are going or you will burn your head.
Like I said go to HF get the damaged bolt extractor set and get at least a 32" breaker bar. Those bolt extractors will grab onto the bolt head and not let go for anything.
Old May 5, 2010 | 02:54 PM
NiteTrain's Avatar
cant get link to work...might be a problem with HF server..anybody else?
