Stripped Head Bolt - Any Help?!
Old May 5, 2010 | 07:53 PM
  #21
audiS4S6's Avatar
Thumbs down UPDATE - Yeah!!! Oh ****...
I got the Irwin bolt extractors from Advance Auto for $25. They looked nice and worked even better. I may have loosened the bolt a bit before the bolt head went bad because it really wasn't that hard to get it loose.
That bolt extractor just grabbed the bolt head and she came right out.
Yeh! Woo-hoo! And there's where the head gasket was blown - cool, blown head gasket confirmed. And there, yeah right there, that's a broken piston -
SON OF A B!ITCH!!!!!
The piston next to the cylinder where the head gasket was leaking has a hole in it along the cylinder wall. Weird.
I will pull that piston and rod and see what I have this weekend.
The night went much better after that. I borrowed my buddy's borescope to look in my radiator. I went to adjust the scope head to get it around a bend and it broke off in my hand. F-me...
will try not to drink too much tonight...
Old May 5, 2010 | 08:49 PM
  #22
WIS ROVER's Avatar
A trick both of my Grandfathers taught me (a machinist and a mechanic) for the really tight ones, is to actually tighten the fastener a little before you try to loosen. It won't move much if it's super tight (maybe not noticeably at all) but it does work.
It won't help with a rounded of bolt head or nut, but I figured the tip might help someone, somewhere. I think it helps particularly with steel bolts in aluminum threads, but I can't be sure about that.
Old May 5, 2010 | 09:37 PM
  #23
vandev's Avatar
Thumbs up your a true land rover owner..
most people would walk into a Land Rover dealership and open up with a machine gun.... it's truly amazing who many things that Fuc&^k up on these trucks...its amazing..they should change there name from land rover to self destruction... I look forward to your posts... keep them comming...
All the best chris
Old May 5, 2010 | 10:02 PM
  #24
greg409's Avatar
And my wife laughs when I say this is Hell,
After this everyone goes to Heaven, (can you imagine how many more rovers have to be sold?)
luck,greg
Old May 6, 2010 | 06:17 AM
  #25
vandev's Avatar
Wink you said it
luck,greg
Isn't that the truth Greg.....
fpdavis3
Aug 23, 2015 09:06 PM
lighting
Mar 16, 2015 09:47 PM
EVN137
Mar 4, 2012 08:21 PM
penniwb
Jan 29, 2010 06:02 PM
sayre05
Apr 25, 2008 09:39 PM
