Strong fuel smell
Old Sep 21, 2020 | 09:02 AM
attworth's Avatar
Default Strong fuel smell (Solved)
Hey all. Lately I’ve been getting a really strong fuel smell during and after driving. I replaced my fuel cap because the gasket was seriously corroded. That seemed to help a little, but not entirely. Every once in a while I’ll get the 0305 code, but not often. And with the windows up, I can’t smell it.
Any ideas what to check? It’s seriously strong, almost like straight fuel is leaking somewhere. But my mileage hasn’t gone down for that to be it I don’t think.
Old Sep 21, 2020 | 01:12 PM
Tidder's Avatar
I have the same issue and I'm beginning to suspect it's where the fuel line attaches to the fuel rail. I guess this piece is plastic and seems to be a common point of failure. The problem is it's under or behind the intake, not an in easy place to see/inspect.
Old Sep 27, 2020 | 06:19 PM
attworth's Avatar
Well I found the cause.... I’m not sure how this is possible, but fuel is coming out the top of the fuel pump when it’s running. I’m assuming the pump has a crack in that area that’s letting fuel pump out.
Before running, after I cleaned up what I suspected was fuel mixed with crud.
About 15 seconds after starting the truck.
Old Sep 27, 2020 | 08:31 PM
Best4x4's Avatar
Yep it's aged and probably cracked. I know for sure the ethanol in the fuel certainly doesn't help the internal wiring of the fuel pump. I've pulled several with almost 90% bare wires inside due to the ethanol in the fuel. You should be able to get a fuel pump for around 150-175.00 for a Non SAI fuel pump.
Old Sep 27, 2020 | 08:36 PM
attworth's Avatar
Thanks, Best. I’ve pulled this one before to check the condition of everything but obviously didn’t notice the cracking.
I went ahead and ordered a Bosch unit from RockAuto for ~$180 shipped with tax. It should be here this week so I can get back on the road.
Old Sep 27, 2020 | 08:39 PM
Best4x4's Avatar
Good deal!
redrover75
Aug 28, 2022 07:03 PM
Brandon318
May 25, 2020 03:13 PM
gte619n
Sep 5, 2019 02:15 PM
Classklown90
Nov 4, 2009 07:37 PM
Bob
Other
Oct 30, 2005 09:36 AM
