Stuck in richmond
Old Aug 3, 2011 | 10:36 AM
DonRW2007's Avatar
Default Stuck in richmond
Car just stopped and will not re-start. Turns over but won't start. Any obvious things to check? Waiting on tow truck...
Old Aug 3, 2011 | 11:03 AM
bosshogt's Avatar
I'm guessing crank position sensor, if you have not replaced it yet.
Available at Advanced, Checkered, AutoZone. Around $70
Old Aug 3, 2011 | 05:42 PM
yloDiscoII's Avatar
$60 at AZ, Duralast brand. I'm going to pick one up this week since I'm going on a trip this weekend and don't want to get stranded.
Duralast/Crankshaft Position Sensor (SU5570) | 2002 Land Rover Discovery II 8 Cylinders 2 4.0L MFI OHV | AutoZone.com
Old Aug 3, 2011 | 09:41 PM
Rearden Steel's Avatar
Don - how are things going? What did you find out? RS
Old Aug 4, 2011 | 04:55 PM
DonRW2007's Avatar
Default Thanks for the help!
It was indeed the crank position sensor. Had the battery checked and cranking amps way low. Replaced it thinking perhaps this was wreaking havoc on some control module. Still only sporadic starting. Replaced CPS and problem was solved. Thanks for all the advice!
DRW
ImQuattro
May 1, 2014 08:36 PM
ericlws66
Jan 13, 2011 03:29 PM
Rof Racing
Oct 18, 2008 09:46 PM
Rof Racing
Oct 18, 2008 09:45 PM
1994discovery
May 28, 2008 03:28 PM
