stuck window -.-
Because head gaskets, abs problems, t-case clunks weren't enough.
My main driver side window is stuck all the way down. Opened it up and can't see anything. Track seems ok so the regulator??
or the plastic rollers that link them. Or the motor. I have seen them with window off regulator, pushed up to closed position, and a screw in the track to hold it. Makes it fun in the drive thru....
It was making some clunking noises. Window would move down about 2 inches and start clunking. It eventually went all the way down and wouldnt come back up. Now when you hit the switch it doesn't even try . But when it does it just clunks.
Sounds like a combination of mechanical (Wheel {My guess}, Track, Rust, Disconnected from bottom plate) and possible electrical (Motor, Wire, Fuse, Switch, etc.). Is there a thermo switch on these to prevent burning out the motor, or just fuses?
Motor is definitely failing. It will randomly try to work. I can see 2 plastic white wheels that are heavily greased and look good on the bottom rail. It looks like that large gear isn't connected to the motor?
EDIT: For what it's worth, I have not yet pulled mine apart on THIS vehicle, so I'm just guessing at the moment. But I've worked on Many Regulators over the years, so am basically knowledgeable about these.
Did I really just say that???
