stuck window -.-
Old Sep 15, 2013 | 05:33 PM
FlyingZebra34's Avatar
I need my windows.. there are 4 bolts on the regulator, is this thing tricky or pretty self explanatory?
Old Sep 15, 2013 | 06:10 PM
SuperSport's Avatar
I believe I've seen a couple threads on that job. Also, in the RAVE, I believe it has a writeup on the job. Both beliefs are from my memory, so take with a grain of salt.
Old Sep 16, 2013 | 01:04 AM
I've torn everything down and it looks like the motor works ok but the gear is ground down? I won't know until I get a T bit tomorrow. Also the large gear seems to be jammed and off the track.
I would replace both parts but I am currently low on cash
Old Sep 16, 2013 | 11:21 AM
And that is where the screw in the track come in until next payday.... or one of those little thumb screw latches for sliding windows (clamps on the track).... or my old standby, duct tape, get a Rover-sized roll...
Old Sep 16, 2013 | 01:53 PM
I've got duct tape holding the window up right now. Would it be smart to just replace both track and motor?
Or do you think I can get away with just the track?
EDIT :
I'm going to buy a used one with a warrenty. At least I'll have a newer motor and track installed. I just can't front the cash for the window now.
Just bought new ball bearings, T-case seals, and enough RTV and oil to redo the front axle.
Old Sep 16, 2013 | 04:10 PM
Are you not near some of the largest boneyards in the country? Like 8,000 people on a Saturday? Thatz a lot of partz vulturez....
Old Sep 16, 2013 | 08:08 PM
Plenty of D1's but rarely any D2's . When they do show up people buy the entire vehicle and haul them away.
I have a long list of random things I want to pull off one but alas, I'm never there at the right time.
Old Sep 16, 2013 | 08:16 PM
Big yards around Atlanta have an email service that will text you when vehicle of interest comes on the yard.
Old Sep 16, 2013 | 09:47 PM
They have so many vultures here they don't care about informing you
Old Sep 19, 2013 | 10:53 PM
So after further investigation I found that the 3 spot welds holding onto the gear came apart. My new assembly comes in tomorrow. Should I add JB weld for additional security?
