Stumbling/missfire, intermitten
Old Jun 13, 2007 | 03:19 PM
  #21
Default RE: Stumbling/missfire, intermitten
ORIGINAL: allardk3
PLEASE HELP!!!
(Can you hear the shouting?)
Thanks for the help!
Mike
So, send me your tele number or I can call you.
Mike
303-862-7680
Colorado
Old Jun 15, 2007 | 10:32 AM
  #22
allardk3's Avatar
Mike,
I left you a message yesterday. I will try you again next weekend.
I think it is getting a little worse....
Could dirty injectors or O2 sensors cause this type of problem?
Thanks,
Mike
Old Jun 21, 2007 | 06:34 AM
  #23
Nitro96's Avatar
This problem seems very much like my problem with my 96 131,000 miles runs great when cold stumbles after a good heat soak. The warmer the weather the worse it gets. I would like to get this thing figured out. DiscoMike if you have some ideasI would like to talk to you.
Old Jun 22, 2007 | 11:29 AM
  #24
RynPkr13's Avatar
I am having the same issues with my 03 Disco with 45K miles. Has anyone really figured out this problem yet? My telephone number is 484-894-8420 if anyone has info.? I am new to this vechicle and already giving me trouble. How do you get to the back side of the plug wires? I will try seafoam hope that helps.
Old Feb 29, 2008 | 11:11 PM
  #25
eric's Avatar
3rd Gear
Hey, sorry this is a year later. I had the same problem in my '97. I tried everything: seafoam, plugs, fuel filter, etc.... I even had it at a Land Rover repair shop, and he could never get to do it at his shop..so it was difficult to diagnose. I know it was not the VSS, because I had already replaced it for another problem. I eventually replaced the battery, and that was the problem!It never did the low RPMat idle again....
Old Mar 4, 2008 | 07:10 PM
  #26
chiasurf's Avatar
My 04 Disco HSE had a problem which sounded like this... it was the coil pack. It also burned up 2 of the plug wires. I had been telling the dealership that there was a problem and that it was idling way rougher then it should. They tried to give me some BS about it being normal to idle rough.
Finally it was running really bad, so bad that you could not help but notice and acknowledge the problem.
Now over a month later....no idle issues. Amazing.
Old Sep 14, 2009 | 11:45 AM
  #27
IDAHODISCO's Avatar
So chiasurf, RynPkr13, allardk3, Nitro96 and the rest of you guys what did you guys ever find out about your missfires how do I fix this??
Old Sep 15, 2009 | 12:16 AM
  #28
IDAHODISCO's Avatar
Originally Posted by idahodisco
so chiasurf, rynpkr13, allardk3, nitro96 and the rest of you guys what did you guys ever find out about your missfires how do i fix this??
please!!!
Old Sep 15, 2009 | 12:30 AM
  #29
98roverguy's Avatar
Originally Posted by IDAHODISCO
please!!!
None of those guys are around anymore. Ghost thread.
Old Sep 29, 2009 | 02:43 PM
  #30
customrv's Avatar
Gents,
For the idle hunting and other idle trouble check the system voltage when this happens, if irratic, replace the voltage regulator or install an external regulator on your alternator. Solves the idle hunting and stumbling 90% of the time.
Cheers,
CRV.
