Stumbling/missfire, intermitten
Old Sep 29, 2009 | 10:04 PM
  #31
IDAHODISCO's Avatar
Originally Posted by customrv
Gents,
For the idle hunting and other idle trouble check the system voltage when this happens, if irratic, replace the voltage regulator or install an external regulator on your alternator. Solves the idle hunting and stumbling 90% of the time.
Cheers,
CRV.
How do you check that? You have my full attention!
Old Sep 30, 2009 | 03:39 AM
  #32
customrv's Avatar
Using a volt meter accross the battery terminals or on anny IGN wire inside the vehicle.
A sign of a very bad regulator is your rev counter bouncing all over through the rev range.
Stumbling on accell could also be fuel rail regulator. Check the hose connecting the regulator to the plenum chamber at the idle valve manifold. Make sure you have good pressure on the fuel rail too. 2.5 - 3 bar. Else check fuel filter and pump.
Misfire could also be dissy amplifier, dissy cap, bad coil or even low voltage on the coil. Also check vacuum advance operation is smooth and correct. Also possible injector trouble or injector wirring or connector trouble.
Cheers,
CRV.
kosho
Dec 27, 2012 06:17 PM
liljhon
Dec 27, 2012 05:20 PM
IDAHODISCO
Sep 17, 2009 08:54 PM
starcraft
Aug 19, 2008 08:11 PM
rovermike
Jul 3, 2007 11:56 AM
