Subtle vibration when turning right - wheel bearings? Again?
Old Jul 26, 2021 | 10:01 AM
Brandon318's Avatar
Default Subtle vibration when turning right - wheel bearings? Again?
I installed brand new front wheel bearings last summer and already had to replace the passenger side one because it died within a few months. The symptom with that one was triggering the three amigos. Fast forward to yesterday, I was driving a windy-ish road around 45-60 mph, and every sweeping right-hand turn resulted in a super subtle, but noticeable, vibration in the left-hand wheel. Any reason not to assume it's another dead wheel bearing?
Old Jul 26, 2021 | 02:21 PM
tnrangerover's Avatar
is there up/down play in the hub when you jacket up the tire and rock it back and forth? how are your ball joints?
Old Jul 26, 2021 | 02:29 PM
The Deputy's Avatar
Yes, jack it up and check left hub. Making a righthand turn unloads left hub bearing, if it is sloppy.
Old Jul 26, 2021 | 03:37 PM
Brandon318's Avatar
Ball joints are brand new (+/- 5000 miles). Still need to jack it up and check play. Will report back.
Old Jul 26, 2021 | 05:25 PM
The Deputy's Avatar
Originally Posted by tnrangerover
is there up/down play in the hub when you jacket up the tire and rock it back and https://expeditionportal.com/forum/f...ures.61/forth? how are your ball joints?
Had a bad front hub on my 08 Silverado while it was still under warranty (it had the 100K drivetrain warranty). Took it in, they said..."there's no play"..."it's okay". Was pretty adamant about it being bad, growled constantly...but they wouldn't budge. Took it to work the next day, jacked it up, and had all four of the other mechanics listen/look at it...all agreed...bad hub. Granted, it had no movement side to side or in and out. Took it to a different dealership and they changed it no questions asked. Asked to look at old one, growled like mad, just spinning it by hand, but was tight in every other respect.
Old Sep 4, 2021 | 12:56 PM
Brandon318's Avatar
Solved... and sadly can confirm that the F I F T H new wheel bearing has cured the issue. The one I took off had zero up/down/side/side play when doing the usual wheel bearing test, but when I had it off, if I pushed in on the bearing while spinning, it was nice and smooth, and if I pulled outward on the bearing while spinning, it was like a bunch of marbles were bouncing around in there.
Anyway... I guess the moral of the story is what we're all coming to experience nowadays - new parts can't be ruled out when trouble shooting.
Also, FWIW, the replacement hub is the same Eurospare POS made in China. AB says it's literally all they can get right now. I already had it throw a 3 amigos code yesterday that I reset and haven't seen again yet, but yeah... lots of top-dollar garbage parts out there for our Discos right now.
Old Sep 4, 2021 | 04:30 PM
The Deputy's Avatar
If l've said it once, l've said it a million times..."it's new" means nothing to me anymore.
Basically, cheap parts put all of the quality parts suppliers out of business or forced them to go over seas, too, and rely on crap manufacturing. Then once all of the quality parts suppliers are out of business...we start paying more for inferior parts and replace stuff every six months. Welcome to..."hey, it's cheaper"...mentality.
Amazon is using the same business model to destroy their competitors. Once every mom & pop, brick and mortar, competitor/business is crushed...prices will go up. Stopped using Amazon a year ago.
Anyhow, glad you're up and running again...for now.
Old Sep 5, 2021 | 11:53 AM
Brandon318's Avatar
Update: The new hub consistently triggers the three amigos. Looks like I get to install hub number 7 this week.
Old Sep 5, 2021 | 12:31 PM
damn I need to install hubs soon. I hate they didn’t just make the damn bearings serviceable on these trucks.
these are the proline units? Are genuine hubs available?
Old Sep 5, 2021 | 12:32 PM
Brandon318's Avatar
Based on my conversation with Atlantic British the other day, these unbranded (in a Eurospare box, Made in China) hubs are the only ones they can get right now.
Brandon318
Nov 4, 2020 12:28 PM
Alex_M
Nov 9, 2015 10:11 PM
er1c
Oct 10, 2013 01:20 PM
hahajohnson
May 19, 2010 07:39 PM
suveer
May 25, 2007 02:31 PM
