..:: The Sudden Not Starting Situation ::..
#31
I had to use jumper cables on Saturday, after replacing all necessary parts. the old batt was on, which I had charged at the beginning of the week and when picked up I was told it had a bad cell, but charged. That is the battery that after all parts replaced we jumped as a last resource and the truck came to life. Next day I bought a new battery, and it started without issues since, until truck died again last night.
#32
Further to the charging thought, are all the charging related cable connections clean? Including any ground connections? Is the engine to body ground connected? I don’t think this is a problem on D2’s, but on my P38 I added a heavy cable going directly from the alternator to the battery. This solved a slow starting issue for me. The original cables (on the P38) seem to be marginally large enough when the vehicle is new.
What bugs me is that it shut off after braking in traffic on a stop light, with no signs or lights,, except for the O2 sensor code and the p1668, both under "pending".
Along my trip there was traffic on the highway and I had to brake for slow traffic, so thankful it did not leave me stranded at that point, but when I was in a "better place". Since it startled a bit when I started my drive home, I was weary that something was off, but again, no other indications, then what I have already explained... what a pickle!
#33
#34
adolfojbonilla (06-30-2021)
#35
#36
From what I am reading/understanding from the OP is it turns over, but does not fire up. Classic CPS issue & then dies once out on the road yet another classic CPS issue, then generic vs Bosch, and finally no cover. Sounds like one of those airplane disaster scenarios you see on TV.
Just to rule out any issues there, I'll replace the sensor and put the cover back on; but again, truck did not start this morning, not even after cooling off overnight, which is the reason why I guess some people throw water at it. But I guess I should start there for now. Thanks.
#37
HEHEHE, yup!... truth be told, it started with the new generic on after being dead for a month, and no cover ...in addition, new kingsborne wires, NGK plugs and Bosch coils were also installed ...and recently a new battery
#38
#39
Never hurts to check the charging system or clean the terminals!
#40
..:: UPDATE ::..
Hello Roverers!
So I went down to my truck with the intent to replace the CSP sensor with a new Bosch; but before, I went under the car to study how I would approach it, since I'm a heavy guy and would need to figure out how and where to position myself to do it "comfortably".
I see that the muffler might be in the way, so I have to give it some thought first.
While the hood was up, and now with a bit more patience than when the truck left me stranded a couple days ago, I followed a recommendation given here and checked all wires were fitted in place.
Three wires on driver side weren't plugged in correctly, so they were lose -reason why I may have felt the slight rough idling of engine after last Saturday job; now all 8 wires have been checked and firmly in place. I also tie-wrapped them neatly away from SAI pipes, or any other heat source, in fact, a couple were already slightly browned from having touched the hot pipes. Gotta follow the recommendation given to buy some shielding fabric for the pipes, very necessary.
Once all was fitted, battery connections tightened, I fired it up and it came alive once again. I shut it off and fired back on a couple times with no issues. In fact, it does actually sounds nice and steady.
I decided to keep it running for a while, while I gather all stuff I took out to work with, and put it away. After some time running, I shut it off and tried to start it again ...and no start ...I tried twice, and no luck ...so definitely it does not start when something gets hot.
It's been off for a couple of hours now, hoping that when it cools off, whatever it is, it will start again. If so, would it actually be the CSP sensor then?
Either way I'll change it later, once the sun goes down a bit.
Let me know your thoughts, thanks I'm advance, and have a nice & safe 4th of July! ;-]#
Hello Roverers!
