Suddenly Tons of Codes...
Get all those codes cleared once you get the voltage issue resolved and see what shows up again.
By the way, the crank sensor code may is your stalling/starting problem so get one installed and see where it all goes.
That voltage is below minimum, 13.6 to 14.4 is required.
I cleared the codes, and they haven't reappeared yet (knock wood). I was suspicious of the crank sensor, so I ordered a new one from BPofU when I ordered the plug wires.
On a seperate note, I checked the location and access to my coils. You guys that change your plug wires w/o removing the plenum must have hands like a 12 year old girl! Needless to say, I ordered the gasket and plan on removing the upper intake.
Well, even after the new battery, she didn't want to start. Finally got her started for the 1.5 mile drive home. She stalled again on the way home and I rolled into the driveway! I let her cool down and launched into replacing the CPK.
What a miserable task that was! 90% of the job is getting the old one unplugged and the new one plugged in!! Anyway, 90 minutes later it was swapped and she started on the first crank!
Now, on to the 8mm wires and the Bosch 4+ plugs...
twistid1
11-19-2012 07:00 AM
scrbear11
06-12-2008 06:36 AM
chris79
11-22-2007 09:40 AM
