Suggested Scanner?
That cheap unit from harbor freight, coupled with a 20% coupon from a local paper = cheapest code reader for generic OBD2 codes. I've had it for four years, and used it on countless vehicles. I had a more expensive unit that always had issues connecting with a vehicle using the J1942.
Luckily, someone twocked it, so I got a superior unit, and they got a problem.
If you want an all-in-one that does everything from ABS to SLS and body module, then there are many $$$ opinions!
Consider the Ultra Gauge, about $70, will read and reset basic OBDII codes, plus provide real time data data display, like coolant temp, and allow alarm points you set (like 220F), about $70 and changes the "wonder how hot it really is" to a much higher pucker factor.
See UltraGauge Automotive Information Center and OBDII Scan Tool
Depends on what you want from a scanner, here is my short list for one that will cover all D2 issues, the Hawkeye, found at Atlantic British or DAP, or the 3130 found at , CanOBD2.com - Tools and purchased at Amazon for around $134.
If all you want is a 3 Amigo scanner the buy it from RSWsolutions,com
on
1 Post
Ditto on the ultra gauge, mine saved me from running my truck with a thermostat that was on it's way out. That idiot light temp gauge in the dash is useless because my truck spiked to 220 and it didn't budge. I however immediately broke out in a cold sweat, my *** went from half dollar to a penny and I pulled my truck over. Lucky for me I was only 2 miles from home so I was able to get it back with it hovering around 215. Moral of the story, knowing what your actual engine temp is will save it.
So, I'm looking for a reader, but to have one that does realtime stuff like that too is pretty cool.
+3 (or was it 4?) on the ultra gauge if all you want to know is codes. To be honest unless you fork over a lot of cash for a scanner the only thing you can rely on in a scanner is codes anyways. You cant really trust the descriptions as they're generic not vehicle specific. The ultragauge also gives you the benefit of a bunch of useful real time data on while you're driving, most importantly engine temp.
