Suggestions about top hat liners?
Old Jun 30, 2015 | 01:21 PM
  #21
DiscoRover007's Avatar
I made a new observation about my tick yesterday. I put her in park and manipulated the throttle by hand. The tick goes away at higher RPMs and when the engine settles back down it stays away. Tricky thing here.
Old Jun 30, 2015 | 01:35 PM
  #22
Fast951's Avatar
Originally Posted by dgi 07
Drop you 15w40 oil and use 5w40. There is a Rotella 5w40. Blue bottle if I remember correctly.
That's a great first step.
The Shell Diesel formulations are good for flat tappet camshaft engines like the Rover V8. The 5w-40 is Rotella T6 Full Synthetic and is good to run all year long, albeit a bit expensive. The Rotella 15w-40 T5 is perfectly fine to run in Summer and will save you a bit of cash. I advise against running the 15w in Winter, however, due to poor cold flow at start-up.
Old Jun 30, 2015 | 02:13 PM
  #23
toofaroffroad's Avatar
If you are looking for tics. I had a bad one for a long time. Finally discovered it was the Fuel purge valve. google it and find it. Put your hand around it and you'll feel the tic plus it'll be quitter. It was a $30.00 fix. not saying thats your problem but if it is...you are happy.
C3racer2000
Jun 17, 2014 08:42 AM
Mojigglins
Aug 30, 2013 06:27 AM
roverhell
Aug 9, 2013 02:49 PM
5bravobravo
Oct 25, 2012 08:14 PM
