Suggestions for Repair on newly acquired vehicle
Old Dec 11, 2015 | 10:35 AM
back9sunday's Avatar
In the 'Major Service' thread, Disco Mike points out that Dexcool should not be used, whereas most the nice folks I've talked to on the Forum have agreed that Dexcool is the coolant to use.
I use the Prestone Dexcool OAT Prediluted stuff. Am I missing something here?
Old Dec 11, 2015 | 11:28 AM
Racer X's Avatar
I am of the Dexcool is bad camp also.
It's not very tolerant of air in the system, and (at least anecdotally) seems to shorten gasket life over time compared to green/yellow coolant.
Old Dec 11, 2015 | 11:42 AM
Interesting! I have to change some hoses anyway so I'll return the coolant and use the green/yellow coolant.
Old Dec 11, 2015 | 11:52 AM
drowssap's Avatar
do a google image search on dexcool, scary stuff
Old Dec 11, 2015 | 11:57 AM
abran's Avatar
You should also make sure you flush the entire system, motor included before changing. Mixing the 2 types creates a paste.
Run distilled water through the system a few times draining in between.
Old Dec 11, 2015 | 11:59 AM
Wow ! That is alarming... And what's crazy to me is that Doug from from Atlantic British clearly recommends the Dexcool OAT coolant in an academy video on what coolant to use. Check it out!
Old Dec 11, 2015 | 12:08 PM
drowssap's Avatar
it great if it never sees air, unfortunately that is very unlikely with a LR.
Old Dec 11, 2015 | 12:42 PM
number9's Avatar
Default Lug Nuts
You may want to see if your lug wrench will still fit the nuts/covers holding the drive wheels and spare. Mine wouldn't go on most without some pretty good taps and then very difficult to remove from the nut. Not something you'd want to deal with on a roadside.
Old Dec 11, 2015 | 12:45 PM
Now that you mention it, number9 , I've tried removing the front wheels but I can't due to the lugs being ridiculously tight. The lug wrench fits on there fine. But Damn those wheel lugs!
Old Dec 12, 2015 | 10:08 AM
evoblade's Avatar
Here is a very informative link with information on DEX-COOL.
Dex Cool
The bottom line is DEXCOOL is not a lifetime coolant and is susceptible to electrolysis (which most people attribute to air exposure in the system). If you change it regularly and/or monitor the coolant for signs of electrolysis, you will be fine, even if you insist on using DEXCOOL. Very interesting read.
My takeaway is pretty much any coolant will be fine as long as there is no chemical incompatibility and you change it every 2 years or so.
