Sun roof leak or somewhere else?
Old Oct 24, 2013 | 11:05 AM
jcvannoy's Avatar
Originally Posted by 94svt50
Its been pouring over the last couple weeks and I have noticed the headliner getting wet right along the passenger side bottom edge. In the picture you can see the discoloration from being wet. Is this from the sun roof or could it be from the upper edge of the gutter to windshield juncture? I was under the impression that if it was a stopped up sun roof drain that the leak would be higher up close to the actual sun roof. The only place wet is just along the bottom edge. Thanks!
Did you ever figure this out? My leak looks just like this!
Old Oct 31, 2013 | 06:50 PM
94svt50's Avatar
Never did its still a mystery. I temporarily sealed the sunroof and I still have the leak.
Old Nov 3, 2013 | 08:48 AM
Racer X's Avatar
You need to seal the surface between the sunroof and the roof of the truck. The seal dries and cracks, letting in a ton of water. More than the drains can deal with. End result is a wet headliner.
Take the sunroof out (remove the drain tray, then push the sunroof up through the opening in the roof), clean all the surfaces, apply a healthy bead of clear RTV, and reassemble.
Old Nov 3, 2013 | 03:22 PM
OffroadFrance's Avatar
D2 sunroofs are very common for leaks even LR knew about it years ago and there is an internal LR bulletin on the subject. Many sunroofs leak due to the mastic seal breaking down where the frame is bedded into the metal roof and the only sure way to fix this is to remove the headlining and sunroof and re-bed the frame onto new marine or auto high quality mastic. The rear sunroof is a bigger pain if you have rear aircon as I do as you have to drill out pop rivets and remove and then later refit the aircon ducts. It's the only way the remove the rear sunroof frame. The other common leak is the cheap plastic drain sumps attached to each sunroof drain frame that has the drain tube attached. The adhesive breaks down and leaks or the small tubes break off which have to be glued back with 2 pack adhesive such as Araldite. It's the same procedure in both cases to ensure you stop the leaks. If you are doing the latter fix you might as well re-bed the frame at the same time. You need to do this job inside a garage or barn if it's likely to rain. When you re-bed the sunroof frame ensure you clean off all of the old mastic and clean the sunroof aperture well with a spirit but ensure everything is clean and dry before re-sealing with mastic. It'll take you a full 8 hour day for both sunroofs or 6 hours for the front only. Have fun and make sure the wife brings you plenty of food and coffee. Good luck.
Old Nov 3, 2013 | 04:27 PM
borchera's Avatar
We had a leak at the floor area on the driver's side. The fix was the drain termination was plugged with dirt.
139K 2003 Discovery
Vai2kdna77
Oct 6, 2014 08:34 AM
GLOCK3462
Aug 5, 2011 07:53 PM
Eak69
Feb 22, 2011 09:12 PM
adowgiert
May 7, 2007 04:07 PM
