Sun roof trim
Old Sep 27, 2018 | 08:10 PM
EAustin494's Avatar
Default Sun roof trim
Ok after weeks of searching I give up. I had a new headliner put in my D2 but the grey trim around the sunroofs is gross and I want to replace it but I can not find it anywhere. Does anyone have a source? I sealed up the holes for the sun shade clips so hopefully I can park my truck uphill without a flood but now I am on hold for new trim. Thanks.
Eric A.
Old Sep 27, 2018 | 08:45 PM
escott16's Avatar
A quick search on eBay pulled a few results , try Car-Part.com - Used Auto Parts Market . Where I live there are several different disco’s with these parts
Old Sep 27, 2018 | 08:51 PM
EAustin494's Avatar
What did you search for on ebay? I have searched so many times and can't find new ones. I have found the used ones are almost as dirty as mine.
Old Sep 27, 2018 | 09:00 PM
escott16's Avatar
Try things like “Land Rover discovery interior sunroof trim , or sunroof finishing trim , model number is in here https://www.roverparts.com/Parts/EDV500160LUMG
https://www.ebay.com/itm/LAND-ROVER-...-/173335161866
Old Sep 27, 2018 | 09:39 PM
EAustin494's Avatar
Awesome! Thank you!!
Old Sep 28, 2018 | 10:23 AM
Sixpack577's Avatar
Mr.Clean Magic Eraser.
Works wonders on cleaning interior trim.
Old Sep 28, 2018 | 02:27 PM
Llamasayswhat's Avatar
Laquer thinner on a rag will cut and remove most all grime and grease on that trim
Old Sep 28, 2018 | 03:08 PM
EAustin494's Avatar
that finisher is kind of fuzzy will it be okay with lawyer thinner? I have used a Big Lots cleaner Totally Awesome on the rest of the hard trim and it works amazing! I am actually fairly sure it could degrease the motor. Lol
Old Sep 29, 2018 | 03:33 PM
Yup, it wont harm the fabric at all. We used it for everything at the upholstery sho I used to work in. They is not to let it SOAK the part youre cleaning. It could seep through and loosen whatever adhesive is binding it to the rubber. Same goes for spot cleaning upholstery in the car and the headliner material
zuke
Aug 22, 2018 03:47 PM
redrover75
Sep 5, 2016 07:36 PM
Clarkee1973
Apr 3, 2015 08:47 AM
DonRW2007
May 30, 2012 06:55 AM
cer308
May 16, 2012 09:33 AM
