Sunroof Drain Pan/Tray
Hi guys,
Got the headliner out of the project Rover today and noticed the PO had broken the nipples off the sunroof tray and tried to glue them back (like it would seal). Anyway, just curious to know if anyone knows where to find a new pan/tray? Or where to run a bead a silicone to just seal the thing off permanently? Thank in advance!
Had a broken nipple on my sunroof... JB weld worked.
Easy to pull the tray and rebed the plastic trays...The old silicone on mine was shot and water would seep through the old silicone, before getting to the drain line. While you have it open, I would check this.
My rubber drain lines were glued onto the plastic nipple, so be careful removing them..I cut the line back to expose the plastic to remove the sunroof tray.
I have zero leaks in my truck.
Thanks guys. Unfortunately, the PO was a complete @$$$ and tried to seal everything up without even reattaching the nipples. Most of the plastic part of the tray is simply gone and the drain hoses were shoved out of the way all together. I'm going to attempt to completely rebuild the thing using fiberglass and resin. Thanks for the help.
bcolins
02-08-2015 09:43 AM
