Sunroof gaskets
Old Oct 26, 2016 | 10:48 AM
velija's Avatar
Default Sunroof gaskets
Morning y'all
Where do I get new gaskets for the sunroofs tired of having an umbrella in the truck
I did fix the little ports/tubs that connect to the tubes that take the water away
But the gaskets are bed and lett My in to much rain
Thanak
Old Oct 26, 2016 | 06:24 PM
Dan7's Avatar
Got mine from roversnorth.com
Old Oct 26, 2016 | 11:10 PM
velija's Avatar
Discovery II, Sunroof - Rovers North - Classic Land Rover Parts
In this link part #20 upper frame seal is that what you got
Just want to make sure I get the right seal/gasket
Thanks
Old Oct 27, 2016 | 01:23 AM
Dan7's Avatar
That's the one, and most likely cause of the leak (or clogged drain tubes), but there are also upper seals, cracked gutters or other possible causes. Happy hunting!
Old Oct 28, 2016 | 02:16 PM
squirt's Avatar
If you want a cheap, semi-permanent fix:
Silicone from the outside, unplug the switches, and you're set.
akilbrid
Aug 20, 2017 12:18 AM
RROJ
Mar 26, 2011 02:37 PM
BigRed98
Jun 21, 2010 12:30 AM
Steve O
Aug 25, 2006 04:26 PM
edthediscoman
Oct 5, 2005 01:58 PM
