Wiring rear lights on roof rack
Old Oct 29, 2016 | 11:08 AM
D11dad's Avatar
Default Wiring rear lights on roof rack
I finally got the front rack lights wired and it was pretty obvious that it could be routed up the windshield pillar...so that wasn't an issue. Now, I have two for the back above the rear gate and I know I want to drop a lead off the rear cargo light to a switch inside the rear gate area, but I don't know where to run the wires from the switch to the outside of the disco. Has anyone done this? I don't really want to make any holes that aren't already there. Thanks.
Old Oct 29, 2016 | 11:16 AM
abran's Avatar
You could use a weather resistant switch outside near the light and run the wires forward and down the a pillar.
There is also a blank plug in the middle of the roof in the back for a GPS antenna, unless you have GPS. But that leads directly under the headliner.
Old Oct 29, 2016 | 01:58 PM
T-rex's Avatar
I ran mine up the pillar in the front and then zip tied them all the way to the rear. Switch is on the left side of the steering wheel - I got a cruise control switch and used that with a relay.
Works great but you do have to work the switch up front.
1danger1
Mar 26, 2013 12:41 AM
psykokid
Oct 21, 2011 11:10 AM
yloDiscoII
Aug 31, 2010 08:02 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
