Sunroof Leaking
Sunroof Leaking
I noticed some water inside the vehicle today, so I read some previous post......and found that my drain tubes are disconnected, I was able to peel back the liner and see. I've taken down the front part of the Headliner and used canned air to clean out the tubes...but I can't seem to re-connect the drain tubes......I'm really not able to see a spot to connect them, I've felt around the area too.......does anyone know how these things connect?
RE: Sunroof Leaking
They connect at the very front onto a nipple on either side. The nipples will be pointing to the sides of the truck. The tubes just slip over the nipples. I found my nipples to be broken off and the tubes just hanging with a bit of tape over the holes in the sunroof module. I ended up having to replace the module in the front. The rear one was ok.
RE: Sunroof Leaking
www.roverlandparts.com Has them, gently used. That is where I got mine. Comes with everything. The only bit you must replace is held on by torx head machine screws all the way round. The rest is held in with urithane. I just replaced the drip channel and saved the rest for a rainy day.
