Sunroof Leaking
Old Oct 28, 2008 | 02:07 PM
crainface's Avatar
Default Sunroof Leaking
I noticed some water inside the vehicle today, so I read some previous post......and found that my drain tubes are disconnected, I was able to peel back the liner and see. I've taken down the front part of the Headliner and used canned air to clean out the tubes...but I can't seem to re-connect the drain tubes......I'm really not able to see a spot to connect them, I've felt around the area too.......does anyone know how these things connect?
Old Oct 28, 2008 | 03:45 PM
Default RE: Sunroof Leaking
There is somebody who knows and I think they have pics. This is a common problem.
Old Oct 28, 2008 | 08:30 PM
Goose_Cat's Avatar
They connect at the very front onto a nipple on either side. The nipples will be pointing to the sides of the truck. The tubes just slip over the nipples. I found my nipples to be broken off and the tubes just hanging with a bit of tape over the holes in the sunroof module. I ended up having to replace the module in the front. The rear one was ok.
Old Oct 28, 2008 | 09:17 PM
crainface's Avatar
The Nipples have broken off my module as well, Do you know of anyway to order a new module?
Old Oct 29, 2008 | 06:25 AM
Goose_Cat's Avatar
www.roverlandparts.com Has them, gently used. That is where I got mine. Comes with everything. The only bit you must replace is held on by torx head machine screws all the way round. The rest is held in with urithane. I just replaced the drip channel and saved the rest for a rainy day.
rally1
Feb 22, 2022 06:22 AM
Spencerfitch
Jun 4, 2010 03:39 PM
kseasley
May 3, 2010 06:45 PM
geoffthepoolguy
Feb 19, 2010 04:28 PM
Kent Green
Nov 5, 2008 04:30 PM
