sunroof motor
sunroof motor
According to RAVE you should be able to close the electric sunroof manually with an Allen key in the slot in the motor. Mine will only turn easily one way (thus opening the sunroof further). I turned it fairly hard the other direction but it won't budge. The electric motor opens and closes just fine but the trailing edge no longer flaps down. Any ideas?
Thanks
Alan
98 Disco 1
Thanks
Alan
98 Disco 1
RE: sunroof motor
Sounds like you let yours get too dirty and out of lube, most likely you will need to replace the sun roof assembly. You might consider buying a good guaranteed used assembly from, http://www.roverlandparts.com/index....S&Category=373
davidlafrance
12-20-2010 08:22 PM
