sunroof motor
Old Nov 18, 2007 | 08:06 AM
alanroberts50's Avatar
Default sunroof motor
According to RAVE you should be able to close the electric sunroof manually with an Allen key in the slot in the motor. Mine will only turn easily one way (thus opening the sunroof further). I turned it fairly hard the other direction but it won't budge. The electric motor opens and closes just fine but the trailing edge no longer flaps down. Any ideas?
Thanks
Alan
98 Disco 1
Old Nov 18, 2007 | 08:10 AM
Default RE: sunroof motor
Sounds like you let yours get too dirty and out of lube, most likely you will need to replace the sun roof assembly. You might consider buying a good guaranteed used assembly from, http://www.roverlandparts.com/index....S&Category=373
Old Nov 18, 2007 | 11:56 AM
Mike, do you mean the guides are out of lube or the motor itself? The roof slides pretty good both ways on the motor using the switch. There was a noise like a sharp crack and from then on the trailing edge refused to close.
Alan
mlelah
Freelander
Sep 3, 2011 03:02 PM
davidlafrance
Dec 20, 2010 07:22 PM
BigRed98
Jun 21, 2010 12:30 AM
ryant06
Mar 28, 2008 09:01 PM
lrd99
Jul 18, 2007 08:18 PM
