Sunroof and Starting
First id like to say I'm not selling after all just cant give it up we are gonna suck it up and fork out the money for gas. but now i have a problem the front 2 buttons for the sunroofs are not working the one for the front roof is but the back one isn't but if i use the button in the back for the back sun roof it opens and closes. any ideas? this is most likely a weak battery or a weak starter but every few start ups it takes a while sometimes 2 tries any ideas on that help would be greatly appreciated
Pull the buttons and check for obvious problems, loose wires etc... If the sunroof opens and closes by the back button sounds like the motor is operating okay. Switch problem.
Check battery performance by performing a load test. If you confirm the battery is good. The Starter could be on its way out.
Make sure the battery terminals are secure and clean, no greenish oxidation is present on or around the terminals.
Boiserover
04-03-2013 01:56 PM
ruggles
02-12-2011 08:46 AM
sickrangerover
02-11-2007 11:44 AM
