Suspen lift
Old Oct 12, 2012 | 02:47 PM
FlyingZebra34's Avatar
Default Suspension lift question about blocks with springs
Ok i have a 2" suspension lift from old man emu. They are heavy duty springs. I have solid front and rear bumper and with all my gear i think my ride height is down to stock so i was curious if I added 2" blocks would give me my desired lift or cause more problems.
Old Oct 12, 2012 | 04:54 PM
lr2001silver's Avatar
Banned
As most would agree blocks or spacers are really not recommended for off road use and from the sounds of it you offroad. That being said if you can afford to upgrade your suspension lift properly that would be best. Blocks or spacers will affect your down travel also and probably affect your vehicle more than benefit you under your circumstances. I would not add more than 1inch spacer to a already lifted truck no matter what.
Old Oct 12, 2012 | 06:57 PM
Sounds good, thanks
Old Oct 12, 2012 | 07:04 PM
ZGPhoto's Avatar
If you go over 3" lift you should start working with altering other parts of the suspension and drivetrain.
Old Oct 13, 2012 | 10:16 AM
What size tires will you be running?
Exactly which part number springs do you have, it can make a difference?
Old Oct 18, 2012 | 02:48 AM
I would like to run some 30's or 31's but what would you recommend mike? I do some moderate to and many advanced trails. (I mean, someone needs to get the jeep owners to stfu about how land rovers cant do anything) . Also i bought the aprings in a kit from arb. Just a "heavy duty" set. I dont remember a part number.
Old Oct 18, 2012 | 06:46 AM
drowssap's Avatar
your stock tire is just a hear under 30 inches to begin with.
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
