Suspension advise
Old 04-30-2019, 07:55 PM
redwhitekat's Avatar
Default Suspension advise
So one of my front shocks is gone blew bearing
now should I go with the 2 inch lift plus the skeleton towers ??
My towers don’t look bad but I heard the Atlantic British skeleton towers are a big improvement. Thoughts ??
Or stick with stock medium duty springs and shocks terrafirm ? Will I regret it later not getting the 2 inch lift
Old 04-30-2019, 08:52 PM
bcurtman's Avatar
I guess I'm out on left field in the dark.
Shocks don't have bearings.
Not sure what difference a shock tower could make. Can't effect damping or ride.
A lift is a nice improvement in my eyes as these rigs sit very low stock.
Old 05-04-2019, 07:51 PM
I decided to install the terrafirma 2 inch lift kit
suprised to find out they are made in China
OverRover (05-04-2019)
Old 05-04-2019, 09:54 PM
OverRover's Avatar
Don't feel bad we all make the TF mistake at least once.
Old 05-05-2019, 02:02 PM
cvhyatt's Avatar
Just started mounting mine yesterday. Video from lucky8 makes it easy and I am a complete noob!
Easier than I thought it would be!
Old 05-05-2019, 05:12 PM
i got my rear done yesterday
the springs are really hard to get it I had to use spring compressors to get mine in and my axels are dropped all the way. It’s been a real pain
Old 05-05-2019, 06:02 PM
Best4x4's Avatar
Received 2,246 Likes on 1,666 Posts
Bottle jack between the axle & frame = coils will go right in (on the rear remove the 13mm nut on each side that secured the ABS/brake line to get more flex). I haven’t used those crazy spring compressors in years.
cvhyatt (05-08-2019)
Old 05-05-2019, 06:33 PM
u mean to force the axle down more
Old 05-05-2019, 07:42 PM
works like a charm.
Old 05-05-2019, 08:25 PM
Best4x4's Avatar
Once the rear brake line bracket is loose (you gain more slack) yep you pump the bottle jack a few times & either remove or install your coil spring.
Quick Reply: Suspension advise
