suspension fuses question ;)
Old Jul 14, 2016 | 08:31 AM
Roverrrgirl's Avatar
Default suspension fuses question ;)
Hi,
Just wondering which fuse actually stops the EAS from rising or lowering is it the F26E ? is this the one people pulls to eliminate the bump stop, limp mode ?
Thanks
Old Jul 14, 2016 | 09:50 AM
Best4x4's Avatar
Pull Relay for SLS
Old Jul 14, 2016 | 09:59 AM
Originally Posted by Best4x4
Pull Relay for SLS
which one is it?
Old Jul 14, 2016 | 10:03 AM
Best4x4's Avatar
Under the hood & marked with the same symbol as the SLS basically. The fuse box lid should show it.
Old Jul 14, 2016 | 12:08 PM
so if I pull this fuse I can drive the car as it sits and wont change height nor go on limp mode correct?
Old Jul 14, 2016 | 03:07 PM
Racer X's Avatar
Provided that you don't have any air leaks (at the bags, air lines, or valve block), the vehicle should maintain it's height.
Old Jul 14, 2016 | 05:15 PM
is it R7 relay? or fuse F26 ? thanks and sorry for the many questions
ps: moved to LR3 Forum
CATTIVA73
Feb 27, 2016 10:20 AM
MoNtErover
Sep 27, 2008 08:27 AM
OxyCoRover
Jan 27, 2008 09:56 AM
The Capstone
May 11, 2006 12:57 AM
