Suspension Knock Knock
Old Jan 10, 2013 | 10:52 AM
coors's Avatar
I do not.
Old Jan 10, 2013 | 12:02 PM
ZGPhoto's Avatar
Open to bonnet, push down hard on the front of the truck. Look at the upper shock bushings for possible failure. If the truck moves up and down freely of the shocks at all, that's your problem. I had a similar knock when mine went.
Old Jan 10, 2013 | 12:35 PM
coors's Avatar
Thanks ZG. I will check that. Are the upper shock bushings isolated or separate from my shocks (which are new Terrafirma's)? I'll ask another way. Are the upper shock bushings pressed into the shock itself?
Old Jan 10, 2013 | 03:49 PM
Big Jim Swade's Avatar
Do you have any poly bushing (instead of rubber) on any of the suspension links, including the shocks. Sometimes they can make noise if you don't keep them greased.
Old Jan 10, 2013 | 08:27 PM
coors's Avatar
Negative on the Poly's Jim.
Old Jan 10, 2013 | 09:26 PM
ZGPhoto's Avatar
They are pressed into the shocks themselves. I had a Terrafirma and an Old man emu upper shock bushing blow.
Old Jan 10, 2013 | 09:31 PM
Fivespddisco's Avatar
On a D2?
Old Jan 10, 2013 | 09:33 PM
How did you do the install ?
Did you pull the towers?
What in getting at is the tower securing rings loose
Old Jan 10, 2013 | 10:03 PM
ZGPhoto's Avatar
Originally Posted by Fivespddisco
On a D2?
Yeah, within a month an a half my front passenger side upper bushing completely blew out, it would just sit there when you pushed the truck down. Tf127
Old Jan 11, 2013 | 09:28 PM
wyrdvans's Avatar
If you are thinking of replacing the swaybar links, I would consider getting some disconnects.
gtuplin
Jul 15, 2012 12:18 PM
salve7
May 10, 2010 01:37 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
