Suspension lift and rear spring conversion questions.
![Exclamation](https://landroverforums.com/forum/images/icons/icon4.gif)
Hey folks,
I've read up on several of the threads on this subject but I'm still left with some questions. I'd like to get a rear coil spring conversion kit but I'd like to also put a lift on it at the same time. Will the OME kits cover that or will the conversion kit be additional? Also, I'll be hauling my dump trailer and tractor from time to time so I was thinking of getting the HD kit to accommodate the weight on the hitch. Any recommendations on kits that will work for under $1000? One other thing is that I just got new Cooper discoverer STT's 265/75R/16 so the lift would have to make room for those. Any help you guys could give me would be much appreciated!
Those cooper's that you have listed up there should fit with no problems especially once you get a kit on your car. They're 31.64 inches total so an OME kit would jack you up an estimated 2 inches total. The only thing with the heavy duty springs is that when you're not towing tractors and other heavy things the ride will be bumpier and a bit more wobbly. I know fitment on D1's is a bit different than D2's but you should have no problem with 31's
I've read a few posts about vibrations associated with the HD kit too. Hmm. Does anybody have any experience with this kit?
http://www.roverparts.com/Parts/8573.cfm
southfloridadiscoII
06-18-2009 08:48 AM
