Suspension lift spacers
http://www.roverparts.com/Parts/SMLR103.cfm
Has anybody used these? What are the pros and cons?
[IMG]local://upfiles/10068/94736235E7CB446DA7C2B595408D987C.jpg[/IMG]
[IMG]local://upfiles/10068/0F5A379A9127476CA24848418C883324.jpg[/IMG]
on
RE: Suspension lift spacers
ORIGINAL: jungle truck
I have a '96 Disco with stock springs and shocks. My plan is to lift with spacers (less money than a spring lift)and replace the shocks at that time.
Is the concept behind the spacers sound or am I better off saving up for a spring lift.
Save up your money and do it the right way. If after installing new coils and shocks, you still want more height then install some spacers.
I have a 97 Disco I with over 100,000 miles and the springs were starting to sag from hauling heavy loads over very rough roads. But daily driving was mostly empty so I did not want a higher spring rate. I opted for new stock springs from Rovers North and added a 1" spacer below the rear springs. I am very pleased with the setup. I have the stock ride (not toostiff)when the Disco is unloaded and at night (with heavy loads)oncoming drivers aren't flashing me their high beams.
That being said I am still interested in the OME springs for larger tires evetually(2" lift) and am interested in how much more noticeably harsh the ride will be.
zoomlenz4u
03-10-2010 03:30 PM
fri3daz3
08-18-2008 09:22 PM
