SVS Electrical Failure AFTER Option B?
Old Apr 26, 2026 | 10:30 PM
CharminULTRA's Avatar
Default SVS Electrical Failure AFTER Option B?
Hi all - I've successfully been running Option B mod for several months, but recently got a Shuttle Valve Switch Electrical Failure code that won't go away. I pulled the SVS and checked the wiring, and removed and re-crimped all connectors. Since Option B changes the wiring, I'm having trouble understanding how to apply the diagnostics here to the Option B setup.
I did notice that there was no electrical continuity between the positive and negative sides of the SVS leads. Does this indicate a dead SVS that I just need to replace with a new one? The current SVS is a cheap $25 no-name brand.
Old Apr 27, 2026 | 04:54 PM
Externet's Avatar
The 8 valve solenoids inside the modulator have the continuity resistance to chassis as sketched here; remove the plug and probe the terminals to confirm :
Post #2 at ----> https://landroverforums.com/forum/di...-sound-119576/
If you feed 12V to each solenoid terminal, should hear them click.
Old Apr 28, 2026 | 02:11 PM
You're saying that valve solenoids can cause Shuttle Valve Switch Electrical Failures? Strange...I'll give it a shot.
Old Apr 28, 2026 | 03:15 PM
Externet's Avatar
Am not saying other than the solenoids resistance continuity are readable at the terminals shown, and I do not see any "positive side" anywhere. There is only loads to the Wabco compfuser to be read/probed at pins 1, 2, 4, 5, 10, 11, 12, 13. and the resistance at pin 9 changes if pedal is pushed.
Compfusersends+to------------------------------>solenoid--------------------------------------chassis pin8.
Old Apr 28, 2026 | 03:28 PM
I don’t understand anything you just said, or how it would address the problem.
Old Apr 28, 2026 | 07:30 PM
Best4x4's Avatar
Verify you have a good ground. Most important step when performing the update/bypass.
Old Apr 29, 2026 | 11:44 AM
Damn! Seems like it was the ground connection, loose screw on the AC line holder. Not sure how I missed that, thank you!
edit: jk still have problems
Old Apr 29, 2026 | 06:52 PM
Well it got weirder…no codes and no lights, but ABS and Hill Descent do not work.
Old May 3, 2026 | 10:42 AM
I replaced my SVS with a fresh one, did Option B to that one, and still get Shuttle Valve Switch Electrical Failure. My ground is good, so I have no idea how this is possible at this point.
Old May 3, 2026 | 12:34 PM
Externet's Avatar
How did you erase ABS error codes ?
