SVS Switch replacement and the "3 Amigos"
Old Dec 8, 2014 | 05:57 PM
sdhow's Avatar
Default SVS Switch replacement and the "3 Amigos"
I won't go into the process of changing out the shuttle valve switch (its been done here more than once), but it's a pointless endeavor if you don't replace the plunger seals at the same time. My old SVS had brake fluid inside it, most likely the culprit of it's failure. The source of the fluid is the plunger seals; the only place I found these is Falconworks in Tucson, AZ. $40 + shipping for two little seals, but better than replacing the SVS only to have the "3 Amigos" revisit in a few months.
jycsalas
Jan 8, 2025 07:38 PM
jycsalas
May 23, 2019 03:02 PM
cammyr01
Jan 5, 2015 02:42 AM
boudini
Jul 1, 2013 02:50 PM
yuenie
Dec 17, 2009 04:29 PM
