SVS rewire and new code
Old Jun 26, 2013 | 02:51 PM
boudini's Avatar
5th Gear
Default SVS rewire and new code
I hope someone can help with this. I recently rewired the SVS on my '99 Disco II and tested with my multimeter--all passed. Once installed, I checked the codes with my ABS Amigo and found that the 114 fault is still present (as evidenced with the 3 Amigos). Additionally, I have a new fault code of 077: Rear Left Out Valve Short to Supply. Not to mention, I bled the brake system to remove old fluid. I'm not getting any fluid to the right front. I did get fluid to both rear wheels, but it looks like foam coming out of the drain tube. What the heck did I do??? Does this sound like a complete replacement of the ABS system? This is my first Rover, so I appreciate any and all help.
Old Jun 26, 2013 | 03:01 PM
bballjames's Avatar
Did you bleed the ABS module?
Old Jun 26, 2013 | 03:04 PM
How much total D OT 4 did you use to bleed the entire system?
Old Jun 26, 2013 | 07:32 PM
boudini's Avatar
5th Gear
I Did Not Bleed The Module. I Was Under The Impression That I Could Remove The Air During The Bleed And Then Activate The ABS/HDC and Then Bleed Again.
I Used About 4 Large Bottles Of DOT 4 Synthetic To Flush.
Old Jul 1, 2013 | 02:50 PM
boudini's Avatar
5th Gear
I found part of the problem. Let me start by saying that my color-blindness is sometimes difficult to deal with. I created the 077 code when I spliced into the wrong wire--it appears to be the Yellow-Grey wire, not the Yellow-Green wire. I fixed the splice and connected to the correct wire. Code 077 is gone, but the 3 Amigos are still hanging around. I checked the switch with my multi meter and everything checks out. I checked the ground connection--all is good. I went back to the splice and all wires are properly connected. I just can't figure out what I have done wrong. Is there possibly something else that could create the 114 Code?
jycsalas
Jan 8, 2025 07:38 PM
lvshust
Aug 21, 2018 02:29 PM
sdhow
Dec 8, 2014 05:57 PM
yesmar
Mar 6, 2010 08:24 AM
yuenie
Dec 17, 2009 04:29 PM
