Swap engines between my 2 DII's
Old Apr 17, 2009 | 06:48 PM
Disco Fuego's Avatar
Question Swap engines between my 2 DII's
Scenario:
2000 DII has 118K miles with replaced 2004 4.6L block with 45K miles
2001 DII has 67K miles with original 4.0L block
If I want the bigger engine to go into the 2001, what does it take? I have never replaced engines... How much time would it take for a mechanic? Cost?
Reason for the swap is that the 2001 has all the off road gear and will be used only when carrying heavy loads on big trips. I think the 4.6 would be more conducive for those conditions.
Opinions and knowledge please....
Old Apr 17, 2009 | 08:25 PM
$3000 plus for parts and labor.
Not really worth it when you consider the value of the truck is around $4000 on the market.
Old Apr 17, 2009 | 08:42 PM
AK Rover's Avatar
What kind of off road gear does the 2001 have? Wouldn't be easier to move the off road gear from one vehicle to the other. Even bumpers, sliders and roof rack would be easier to transfer than the engine.
Old Apr 17, 2009 | 09:12 PM
$3K for swapping the engines??? Wow!
The 01 has everything from bumpers to lights, sliders, arb lockers, truck vault drawers, OME suspension, it's ready to go.
What parts need to be replaced when doing the swap?
Old Apr 17, 2009 | 09:51 PM
I forgot to mention the snorkel, light guards f/r, winch and heated seats for my better half...
Even if i would move all that, the problem with swapping the bumpers is that one is white, the other gold. Now I need a paint job too... If swapping the engines is not feasible I would leave it as is. But I would really like the extra HP combined with the lower miles. We potentially have some big travel plans for that one carrying lots of gear and driving long distances...
Hmmm, I just can't believe it would cost $3K... You can buy a new engine for less!
Old Apr 18, 2009 | 10:16 AM
You'll have over a $grand in labor, lots of fluids, replacement parts, seals and the expnse of partially going thru a used engine prior to installing it.
$3000 could be on the light side.
Old Apr 18, 2009 | 10:43 AM
ok, so forget that...
Thanks Mike!
Old Apr 18, 2009 | 12:51 PM
AK Rover's Avatar
The 4.0 is more than capable of hauling the kind of load you're talking about. Do you know what gears are in the axles of the 2001? I would bet that with all the other work done to the truck it has been regeared also.
The 4.6 only makes about 30 horsepower more than the 4.0. That little difference inn power is barely going to noticeable and definitely not worth the cost of swapping the engines. I think you made the right decision leaving the engines where they are.
Old Apr 18, 2009 | 01:10 PM
Not sure about the gears... How would I be able to tell? The car will be delivered on Wednesday. First things first though... 60K service!
reporob
Feb 27, 2014 07:31 PM
shk109
Dec 12, 2013 03:05 PM
tulsadiver
Jul 6, 2011 02:11 PM
Faymester
Apr 2, 2009 06:09 PM
