Swapping dash lights with LED bulbs? Brighter?
Old Sep 27, 2013 | 01:34 PM
Chrisinhouston's Avatar
Default Swapping dash lights with LED bulbs? Brighter?
As I get closer to age 60 my low light vision seems to decrease and I notice I have trouble clearly seeing the gauges on the dash and tend to at least turn on the parking lights in order to light up the dash but in the daytime that doesn't help that much. The dash cluster on the Discovery is set back with all the black around it I wish there was a way to brighten it up.
Does anyone know if LED bulbs would help? At one of the LR forums I read about someone swapping their out and liking the difference.
Old Sep 27, 2013 | 02:23 PM
I think you will find them brighter. I replaced the overhead lights with LEDs and big difference. I can see to check the map or Depends.
Old Sep 27, 2013 | 04:57 PM
Listen, I wear readers in low light and sunglasses with readers in the lower half for sunny driving. Without them I couldn't see much of what the gauges say! Depends might not be far off!
Old Sep 27, 2013 | 09:32 PM
Pix of front, back seat is still regular bulb.
Attached Thumbnails Swapping dash lights with LED bulbs? Brighter?-p1020476.jpg
Old Sep 28, 2013 | 12:01 PM
SuperSport's Avatar
I bought these: 10x 42mm 8 LED Pure White Car Auto Interior Dome Festoon Light Lamp Bulb DC 12V | eBay
When I first installed them, they seemed brighter, but now, after a couple months, they are getting dimmer and start to flicker after being on for a while. I'm guessing that is due to them only being $6 for 8 bulbs and direct from China.
I went with these because some members said theirs were too bright. I felt it was a decent compromise, but now, I'm considering going back to stock bulbs.
PS: I also put them in my Wife's car and they have burned out already.
Old Sep 28, 2013 | 04:22 PM
OffroadFrance's Avatar
Hi
I have replaced the dash lamps, A/C ECU/controller and interior festoon lamps with LED's and it really makes a difference. They are all available from Hong Kong on Ebay for a few cents each and free postage. It is a worthwhile exercise.
Old Sep 28, 2013 | 04:49 PM
TRIARII's Avatar
you could just replace all the bulbs with new stock replacement bulbs. Will be easier and it should make the guages bright like they use to be. That's actually my next project.
Old Sep 28, 2013 | 05:22 PM
jalodge's Avatar
How do you get to the bulbs?
shaneb24
Jun 17, 2015 09:40 PM
OffroadFrance
Jan 28, 2015 05:21 PM
mtrdrms
Feb 20, 2013 06:24 AM
AdrenalinPlease
Jan 31, 2013 05:43 PM
RenoHuskerDu
Oct 16, 2011 08:28 AM
