Swapping out drivers seat bottom
Old Apr 11, 2026 | 09:07 PM
Frank4's Avatar
Default Swapping out drivers seat bottom
I found a seat bottom in excellent condition to replace my worn out ripped drivers side. Has anyone attempted this without taking the entire seat out? If so any tips would be much appreciated.
Old Apr 11, 2026 | 09:16 PM
JohnZo's Avatar
Exmoor Trim has good videos online for that. Taking the seat out is not too difficult.
Old Apr 12, 2026 | 10:10 AM
longtallsally's Avatar
Honestly, taking the seats out isn’t too hard. It’s 4 bolts (one has a but) and the electrical connectors. About the only part that is a challenge is the seats are relatively heavy and pretty cumbersome to get out, but in my opinion that would be easier than trying to snake your way in and replace the cushion with the seat installed.
I think the Rave has the procedures for disassembling the seat, but no matter what, I’d say it would be worlds easier with the seat out.
Old Apr 12, 2026 | 05:15 PM
Extinct's Avatar
I have done it both ways and it is about the same difficulty either way. To do it with the seat in I start by reclining the seat fully to reduce tension on the seat back leather and then roll the rear retainer off/out. Giving yours is no good to start with you can cut the other three loose. Putting the new one in with it in the truck start with the retainer on the console side then do the opposite side and then the front and finish with the back. It helps if you raise the seat all the way up and it's travel so you can get to the retainers.
Old Apr 12, 2026 | 07:17 PM
PickleRick's Avatar
Removing the seats is an easy task in these guys. To me, it would be much easier to swap out the cover on a bench with easy access. But I'm lazy.
Old Apr 12, 2026 | 11:14 PM
Frank4's Avatar
Thanks for the tips. Much appreciated.
Old Apr 18, 2026 | 07:03 AM
nashvegas's Avatar
The plastic holding mechanisms on the leather will break if they’re old - so be prepared for that. I’d remove the seat from the car.
Old Apr 18, 2026 | 08:13 AM
Externet's Avatar
----> https://landroverforums.com/forum/di...estion-126947/
disco96sd
May 19, 2025 06:24 PM
jastutte
Apr 6, 2023 06:25 PM
ABC
Apr 17, 2022 03:31 AM
KlamathMatt
Feb 12, 2017 08:29 PM
rover2003
Nov 7, 2007 09:53 AM
