sweet score at HFT, lights and oil pressure gauge!!!
hey guys,
i was at my local harbor freight tool store today to buy some rubber mats for the cargo area of my D2 and i came across this amazing deals...
Off-Road Long-Range Truck Light System
Powerful 100 watt halogen beams keep you from overrunning your headlights.
For off-road use only. 7-3/8" W x 6-3/8" H x 3-3/4" D
ITEM 3029-9VGA
$25.99
And a electric oil pressure gauge with 7 different colors
2" LED Lit Oil Pressure Gauge
This electric LED oil pressure gauge has a white face with 270° sweep and adjustable seven-color LED lighting.
2-1/16" diameter case, 2-1/4" diameter bezel, 1-3/4" diameter lens, 2-1/2" L
Weight: 0.7 lbs.
ITEM 98475-1VGA
$24.99
The lights fit the front brush bar perfectly, and i'm wiring them to a switch/fuse/relay for use at any time. F-ing sweet find IMOP!!!!!!!
Does anyone have pics of a mounted oil pressure guage near the dash, currently its going it the center console armrest
![](http://www.harborfreight.com/cpi/photos/03000-03099/03029.gif)
- Lightweight high-impact body
- H-3 halogen lamp
- Tempered glass lens
- Unbreakable high-polish metal reflector
ITEM 3029-9VGA
$25.99
![](http://www.harborfreight.com/cpi/photos/98400-98499/98475.gif)
- Pressure ranges from 0 to 100 PSI
- 12 volt DC
- Includes a full pointer to ensure easy and accurate readings
- Gauge fits into a compact 2-1/16” mounting hole
- Electric gauges help keep hazardous fluids in the engine compartment
- Seven different LED color lightings to choose from: white, blue, green, yellow, orange, pink and purple
- Aluminum flange with satin finish
- Includes all necessary hardware for installation
Weight: 0.7 lbs.
ITEM 98475-1VGA
$24.99
If you go to - glowshift gauges - they have the 3/4 x 16unf oil filter adapter kit that I installed two weeks ago.
I gave up after 2mos. & $20 in fittings trying to convert my factory setup.
The oil filter adapter is great & SIMPLE!
I put a 3gauge pod in the recess on top of my dash.
luck,greg
luck,greg
lipadj46
02-16-2010 05:20 PM
Pepe Pepe
12-21-2009 02:16 PM
