Switched to Royal Purple...started leaking
Old 04-10-2009, 01:20 AM
KBW's Avatar
KBW
KBW is offline
Default Switched to Royal Purple...started leaking
I'm not upset as I had a very slight knock that went away when I changed to royal purple 10w40 but I did not leak a drop before (park in a garage with a tile floor) and now I have a very small puddle every time I look. I'm guessing the Royal Purple just cleaned my seals of the buildup that was keeping them from leaking.
How hard is it to change these seals?
Also I'm starting to notice a rattle or some sort of noise when I switch from park to reverse and the rattle only happens in reverse (or else it is only loud enough to notice then).
Old 04-10-2009, 03:09 AM
sloppyjoe's Avatar
personally i am not a fan of RP at all.
i would have recommended either Amsoil or Mobil 1 high mileage. both are superb oils.
the Amsoil along with being a fantastic oil is also recommended for flat tappet engines, which ours is.
the Mobil 1 HM has a seal conditioner that might have prevented this. but as is the case when switching from any dino oil to a synthetic there may be some leakage. it should go away in time. i would not worry too much into it.
Old 04-10-2009, 08:14 AM
KBW,
didn't you get enough feed back from the LRO to satisfiy you?
There is nothing wrong with Royal Purple and it is a long known fact that switching over from dino can cause bad or loose gaskets to leak. Might want to start working on correcting your leaks.
Old 04-10-2009, 09:16 AM
Disco_Fever's Avatar
Originally Posted by Disco Mike
KBW,
Very few at LRO seem to be able to offer feedback without being a complete ****. And over there for every helpful person there seems to be 2 that want to stir the pot and start drama. I remember now why I spent most of my time here, and am very glad they got the threads sorted out here. You can't even talk about stickers over there without a big rash of shyte! And the Oil thread that Jupiter and I had contributed to got hijacked and turned into what looks like a name-calling contest between teenage girls. They talk more about miscellaneous shyte over there and less about Land Rovers, and when they do talk about Land Rovers they just attack one-another. You know that Mike, I saw in a recent thread where the "machine" that is LRO was turned on you.
I don't blame KBW for reposting his question/concern here!
Old 04-10-2009, 09:20 AM
llPANCHOll's Avatar
I leaked a little bit after the switch, I would leave it alone for a while and see if the seals swell back up.
Old 04-10-2009, 03:58 PM
04BluDisco's Avatar
Pancho, you really have a 1994 Disco with only 48K miles on it? Impressive....
Old 04-10-2009, 06:26 PM
The leaking will go away, just keep a close eye on the oil level.
Mine leaked like a colander for the first 12,000 miles or so and then it stopped.
I use Mobil 1.
Old 04-10-2009, 06:44 PM
KBW's Avatar
KBW
KBW is offline
Mike as I wrote in my OP I have to fix the leaks. I quit reading LRO. I read this forum and dweb even though there's a lot crazy people on dweb I still learn a good bit there.
Old 04-11-2009, 12:40 AM
llPANCHOll's Avatar
49,000 now I should update my sig..
And my engine only leaked for about a week, and not very much..
The Transfer Case.. I fear will require a new seal at least... Hope the output shaft didnt get pitted from sitting idle for so long..
Old 04-11-2009, 10:01 AM
Sorry,
I spoke out without reading all of both posts.
Exactly what seals or where is the engine leaking?
Quick Reply: Switched to Royal Purple...started leaking
