Switching coolant...should I do it?
Old Mar 20, 2013 | 12:06 AM
dr. mordo's Avatar
Originally Posted by CANAMDiscovery
I hear that the issue with Dexcool is if left unchecked, and not changed on regular intervals it becomes an issue.
This is certainly true. Part of the problem with dexcool is the manufacturers recommend using it for extended periods without flushing.
But also it turns to sludge and/or crust when exposed to air.
So, as long as your cooling system is working perfectly and you change it every 2 to 3 years, dexcool is ok.
But if you develop a leak, expect sludge. If you leave it in too long, expect sludge.
Seriously - why would anyone use dexcool? Does it have some positive aspect I haven't heard of?
Old Mar 20, 2013 | 01:05 AM
LRScott's Avatar
Supposedly its more "environmentally friendly", which is why manufacturers started using it. All my vehicles run either peak or the conventional green coolant.
DooDer
Oct 29, 2009 10:52 PM
millejdq
Dec 6, 2007 12:23 PM
99XJ
Mar 20, 2007 02:17 PM
hoberock
Jul 18, 2006 10:24 PM
htxb
Sep 21, 2005 04:46 AM
