Swivel oil
Saw this link.
http://www.landroverclub.net/Club/HT...e_greasing.htm
Is this the same procedure to what should be done to the D1?
Swivel Oil..
Can sombody elaborate on what and where this is???
Is it the Ball on inboard side of the Hub on the front wheels??
Thanks alot for that link..
I would have done it all wrong..
I worked on a Wheat farm and had to grease the implements and tractor every day..
The guy who oned the farm was very insistant that I only put 2 pumps every fitting every day, or I would blow the seals..
I would have just put in enough to push out a little of the black stuff, and not all of it if I hadnt seen this link..
Thanks again..
This forum is a great resource,
Only trick is.. Read every Thread!!
ORIGINAL: DiscoRom
Saw this link.
Saw this link.
Thanks again..
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
Yes it is the big shiny ball looking thingy on the inboard side on the front wheels.
There is a square nut on the top front of it, 1/2"? open end wrench to remove it.
Some have a drain plug at the bottom, dont worry about this if you have one.
The swivel ***** were supposed to be filled with gear lube, but it leaked, so they went with a gear lube/grease mixture, then all grease.
Use the same grease that you use on everything else in your swivel *****.
