Synthetic to Conventional Oil? Problems
RE: Synthetic to Conventional Oil? Problems
You need to clean the outside of the t-case. Those leaks that you are seeing could be old and it no longer leaks, it could be motor oil, P/S fluid, trans fluid, anything. Anything that leaks from the front will run down everything that is behind it and can make it look like something else is leaking even though it is not.
You need to start by cleaning the underside of your trk.
LR t-case's do not have a pump, they use something better and much more reliable, splash lubrication.
The gears are partially submurged in gear lube and as you move they spin and the teeth pick up the gear oil and sling it around. Works every time. No matter what the angle your trk is at.
But yes, you could clog your breather tube.
