Synthetic to Conventional Oil? Problems
Old Jul 6, 2008 | 08:26 AM
Default RE: Synthetic to Conventional Oil? Problems
You need to clean the outside of the t-case. Those leaks that you are seeing could be old and it no longer leaks, it could be motor oil, P/S fluid, trans fluid, anything. Anything that leaks from the front will run down everything that is behind it and can make it look like something else is leaking even though it is not.
You need to start by cleaning the underside of your trk.
Old Jul 6, 2008 | 09:09 AM
ljdiscovery's Avatar
Believe me, it is spotless under the truck. You should see my Simple Green budget. I tried to upload some photos but couldn't get them to upload. Thanks Phil
Old Jul 6, 2008 | 09:12 AM
Ok, you didnt state that you cleaned it.
You could try any one of those stop leaks, what do you have to lose right? Personally I wouldnt.
Old Jul 6, 2008 | 10:55 AM
roverguy7's Avatar
i agree with spike here, dont use them, theres a good chance youll end up 'sealing' the leak on your pick up for the fliud pump... bad idea, in case the sarcasm didnt show up enough
Old Jul 6, 2008 | 11:49 AM
LR t-case's do not have a pump, they use something better and much more reliable, splash lubrication.
The gears are partially submurged in gear lube and as you move they spin and the teeth pick up the gear oil and sling it around. Works every time. No matter what the angle your trk is at.
But yes, you could clog your breather tube.
muddybuddy
Jun 4, 2009 08:50 AM
herblatham
May 1, 2008 05:57 PM
chrisusvi
Mar 3, 2008 08:24 AM
GCS1
Aug 9, 2007 07:26 AM
GA ROVER
Apr 15, 2006 11:51 AM
