system is to lean
Old Mar 31, 2011 | 06:25 PM
ajmille's Avatar
Default system is to lean
Just wondering, if (p0171) System to lean bank 1, warning lite came up as I had a vacume leak in the cruise control.I did repair it and the cc is working. The horn on the other side is still acting up, I found a blown fuse, replaced it, it worked once, fuse didnt blow.Once the truck is off for a while, it works once, thats it.Could this be a bad relay?
Thank you for looking
Old Apr 1, 2011 | 11:19 AM
Snafu / Disco Fries's Avatar
What do you mean by "horn on the other side"? The left button works and the right doesn't or vice versa? Also, when you say "works once" does that mean it beeps once and blows the fuse or beeps once and doesn't blow the fuse, but you need to shut the truck off and on for it to work again?
Nov15
Aug 19, 2020 10:24 PM
2000 Disco 2 SD7
May 3, 2008 07:10 PM
ToddinLou
Freelander
Jan 28, 2008 02:36 PM
trevorr
Nov 15, 2007 08:29 AM
