system too lean codes
Old Sep 26, 2007 | 02:23 PM
Default RE: system too lean codes
02 sensors are not the cause for most lean bank issues. Could be the MAF starting to fail, but if it is dob't try and clean it, that will just assure you that you will get to buy a new MAF, they don't take to being cleaned. To be a MAF failure you would also need to have a 4th. gear out of ratio fault showing as well.
Exhaust leaks, vacuum leaks any number of things will throw lean codes
Old May 3, 2008 | 06:35 PM
bmkraus's Avatar
Mike,
I just had my truck throw the two codes today....
P0171-System too lean (Bank1)
P0174-System too lean (Bank2)
If what I am gathering from this thread...theres not much I can do until I start throwing other codes as well...is that correct? I currently have 88086 miles on the truck. Any further insight would be greatly appreciated!
Old May 3, 2008 | 07:10 PM
jkid's Avatar
Just to be sure, make sure you have the o-ring that fits in the MAF sensor housing, just before the sensor. It's a big 1/4" thick, 3" ring, you can't miss it. Unfortunately, I did and I was getting all 3 codes off and on for months (mostly the 4th gear ratio). I replaced the ring a few days ago and no codes so far, but time will tell. Of course, this morning I found my old ring when I was cleaningthe garage, I'm guessing it fell out when Ihadreplaced my air filter [sm=headbang.gif].
Also, Iwas getting lean codes and the 4th gear code when my crank sensorfailed and the truck died.It seemspossible that my sensor has slowly been dying and throwing those codes intermittently if the engine were to momentarily quit while driving.
StillRoven
Mar 6, 2025 09:37 PM
Nov15
Aug 19, 2020 10:24 PM
dmccoig
Apr 5, 2010 11:19 AM
ToddinLou
Freelander
Jan 28, 2008 02:36 PM
trevorr
Nov 15, 2007 08:29 AM
